Boat is going in the water, but snow (?) is in the forecast.
Peg_O_My_Heart
Member Posts: 30 ✭✭
Here in the midwest, we are used to weather changes. We are moving to a new harbor in Indiana off Lake Michigan this season (new harbor is about an hour from our house). I don't have a bilge heater. The forecast is for next Tuesday to have a low of 32 degrees. At what point, temperature wise, should I have to worry about things freezing that shouldn't freeze?
If it was me I'd not flush water systems of antifreeze yet and before you get the cold snap, run your engines up to temp for a while. Get some heat into that cast iron.
There's a slight risk to the fresh water systems including the galley pump and AC pump. Do you trust your HVAC system? Turn it on, set it to 65 deg, and check it the next morning.
