Hatch doors in 290EC etc, where to find?
JohnnyCakeJohnnyCake Member Posts: 29 ✭✭
I'm considering to change that cold box holder from my 250EC to cabinet doors, since we don't need the box.
The place is acting as holder for BBQ, Honda Eu10 generatorand othet random stuff, but it would be more convenient if there would be a hatch door and stuff inside than all over the boat...
You can figure out my plan:
http://stonebay.pic.fi/kuvat/2012/Tour+de+Saaristo+9.-22.7.2012/Taalintehdas+-+Södra+Benskär/IMG_7557.JPG
http://stonebay.pic.fi/kuvat/2013/Parainen+-+Jussarö+-+Espoo+26.-28.7.2013/IMG_5144.JPG
So the question is, where can I find doors like in the new 290EC. Who's the manufacturer?
http://204.232.205.47/~nauticgl/gallery/boats/927/i/660/RNK_290_EC_54__927.jpg
    Hi, You should contact Cindy at Rinker she would help you out since the are the manufacture. cscott@nauticglobalgroup.com Paul
  • Capt RonCapt Ron Member Posts: 217 ✭✭✭
    You can also look in the West Marine catalogue, they have plenty of doors and hatches that will fit your application.
    Only way you will get the same contour is probably right from Rinker.
    Gary and Diane
    290 FV Nauti Bonnie
  • JohnnyCakeJohnnyCake Member Posts: 29 ✭✭
    I took the ice box mount of and made a cover from 5mm thick acrylic. I used old screws and holes and put some glue also there.
    Then I sawed a hole for the hatch and put it in place. The whole work took about 2 hours and cost about 100 euros.
    The gen is locked with a bicycle spiral lock.
    Here's a couple of pics to inspire you
    edited April 2015
  • Dan4754Dan4754 Member Posts: 80 ✭✭
    You sold me!!!
    Much better use of that space.
    That looks great Johnny, like it came from the factory that way. Who makes the hatch, approximate cost, and what are the dimensions?
    that is sweet! i second what andyd said. size, cost, location?
    Location was Helsinki, Finland. ;)
    I bought the hatch from a local boat/caravan -shop. Cost was about 80 euros (about $90). I was looking for the biggest hatch they had.
    I also bought a big  white acrylic plate from the hardware shop, cost about 15 euros.
    I dismounted cooler holder, and the dimension of the hole on the boat was about 52x53 centimeters (about 20,5 x 20,5 inch).
    I draw the shape of the hole to acrylic plate using the dismounted holder and cut plate to the same dimension that the holder was. After that I just cut the hole for the hatch to the plate. After that, just some screws and sealant and there it was. I used old screws from the holder and the plate is on the same place than the holder was, so it's easy tho change back to holder+cooler if I ever want.
    edited June 2015
    thanks Johnnycake! i did my swap today. i got my hatch from great lakes skipper for 80 dollars shipped. i had to trim a little out of the corners and about a 1/4 inch off the top of the original hole. it worked great!! only took about an hour from start to finish
    Great work!
    Wow those are the tightest boat slips I have ever seen. Why do they do that in Europe?
