Power steering to transom cooler hose
Stever00
Member Posts: 145 ✭
Just posted a discussion asking about grease fittings and lube points on steering. Pat310 sent me a manual . Thanks! I didnt find any grease fittings on my steering linkage behind the motor. This is 97 Mercruiser Alpha One Gen 2. I did find a grease fitting on the shaft from motor through transom. I opened a can of worms once I started looking. I found my power steering cooling hose was almost collapsed completely. Not sure why it got this way. Maybe time, heat and the tight place on steering it's in. I got it off but it wasn't easy.
I ordered a new hose for little over 50 bucks from place in Florida.
This is off the subject but I have another question. Is the sink water in the bathroom head suppose to run out inside the hull of the boat? I know it does cause I put food coloring in sink and let it run. Had blue water running out the plug drain. The sink in galley runs out the side of the boat.
Here is my power steering cooler hose.
