2000 270 horn wiring access
I need to replace the horn on my 2000 270. The existing wiring coming out is very brittle and short to try to tap into. Anybody know the best way to access the wiring from inside the cabin? I am guessing that I remove the large panel on the left as you walk into the head. But just wanted to confirm before I spend the time pulling it out. Let me know if anyone has any ideas. Thanks.
@gherkin if that doesn't work then I think you're on the right track, easier than trying to remove the panel on the v-berth side. Seal it back up well after of course. But Rasbury's suggestion could work as long as they didn't tie wrap the wires together at the factor or something.
