B3 prop alignment
2
    IanIan Member Posts: 2,792 ✭✭✭✭
    Cool demo! Bookmarked!
    YYZRCYYZRC Member Posts: 4,946 ✭✭✭✭✭
    My 4.5 year old is mesmerized by your props!
    aero3113aero3113 Member Posts: 8,866 ✭✭✭✭✭
    edited April 2020
    Awesome demo!
    For 4 X 4 props it doesn’t matter, from Hill Marine.
    See the bottom *
    I’m still going to time mine.
    Post edited by aero3113 on
    edited April 2020
    It's so easy to align them ... I'd do it anyway.
    Post edited by LaRea on
    TonyG13TonyG13 Member Posts: 1,293 ✭✭✭✭
    Ok @LaRea, you for sure are a geek...JK! Awesome, but...so in your wrong set up, the props are aligning on the top as let's say 12:00. In the example of correct, they are aligning the same but at say a more 1:00 position...still don't get the problem! Now, when I put my props back on, I did align them correctly but still don't get why.
    @rasbury , the demo doesn’t have a cavitation plate in it. You don’t want the blades to align under it.
    Thanks @aero3113, I updated the animations with the cavitation plate and the skeg.
    OK, great, now we all understand the geometry of prop alignment.  As @rasbury said -- so what?  Why does it matter?  What's the penalty if your props are misaligned?  Is it vibration, loss of thrust, prop damage from cavitation?  And is the effect large enough that you could actually notice it?
    Thanks! Pretty sure mine are ok but will double check to be sure
    For sure on the check list
    davidbrooksdavidbrooks Member Posts: 1,353 ✭✭✭✭
    ok so for those of us that have moved to the Hill 4 blade props...What are the recommendations on alignment?
    edited April 2020
    @davidbrooks , see my post above. That paperwork was from Hill Marine.
    SpyderwebSpyderweb Member Posts: 885 ✭✭✭
    @LaRea Fantastic demonstration!
    I checked mine this am and they are not aligned properly...
    I made one more update, and now I swear I'm done.  Every time two blades pass, it makes a mark where the pass happened.
    With 3x3, it's straightforward ... blade passes every 60 degrees, and your alignment determines where they occur.
    Like the 3x3, the 4x4 is easy to figure out.  Blade passes every 45 degrees.
    What's really interesting is the 4x3.  The blade passes happen every 15 degrees around the entire circle.  Even with "perfect" alignment, you still get blade passes that are almost at 12 o'clock.  That's why alignment doesn't matter with 4x3.
    And so concludes my lunch-time brain exercise.  Back to work.
    WillhoundWillhound Member Posts: 4,189 ✭✭✭✭✭
    That is freakin awesome @LaRea.
    Now I am not trying to start an argument but I would be curious if someone could in stall the props both ways on a twin. 1 aligned and 1"not" aligned and see what the difference is. My guess........... none. Although the drawing by @LaRea are nice but with the speed of the props and the turbulence of the water I am will to bet that there is no difference. Also if this is the case and its a big deal than this forum and any boating forum would be blowen up with the topic. Alot of these performance issues we talk about would go away because of this. Why are the splines and shafts keyed? Sorry I just don't buy it............ lol I love all the comments....... Go!
    Raybo, here's the complete, unabridged list of reasons I know to align the props.
    1) Mercruiser says to do it (but they don't explain why).
    So I'm with you!  We need data!
    Let's find somebody who has:
    * a Bravo 3 with 3x3 props
    * A boat lift or trailer so they can change the prop easily
    * Good nav electronics that show real-time fuel consumption
    Remove the rear prop and install it wrong.  At your normal cruise RPM and trim, measure speed and fuel consumption while listening/feeling for unusual vibration or noise.  Then align the prop and repeat the test.  Did it make a difference?
    Who will volunteer?  The boating world needs you.
    @LaRea I do not agree Merc says to do it. Like I showed everyone I contacted them and their service center said that there in NO timing on the props.
    edited April 2020
    They might say that now. When that dialog from Merc changed, nobody on this forum knows that answer. All I know is that for all of the years that I helped out the mechanics at the marina where I dock at, they were told to time the props.  As far as I am concerned, I am going with what my mechanic and Al have taught me, which is time the props.
    @raybo3, RTFM.  We have it in writing that Merc says to align 3x3 props.  What they don't say is why they make that recommendation.
    To quote one of the many forum threads I've read:  "There are a lot of people who believe in astrology too."
    Great demonstration. I do enjoy steering at the pics. @raybo3 just do it because we asked nicely that's a good reason.
    BTW I've tried before to debunk unproven boating wisdom.  Long-time readers might recall my debate with The World about outdrive coolers.
       World:  We all need drive coolers.
       Me:  Why?  My drives don't overheat.
       World:  As anybody knows, cooler is better.  It just is.
       Me:  But why?  How does it make a difference?
       World:  ...<silence punctuated by cricket noises>
    Somebody please volunteer to test the prop alignment theory!
    I'm still in this belief too.  Between the two of us, we do a lot of boating.  I look at my drives after every weekend when I lift the boat back up.  No chalky white.  Lube looks good in the fall when I change it....sorry, back to topic. :)  I don't have any problems with alignment of my Big Cow Hill Marine props!  Only need one on each of my Bravo drives! :)
    @Dream_Inn wise guy....lol
    Prop burn on the aft props ... sounds like cavitation.  So you combine the turbulence from the drive body, plus the prop wash from the front blade, plus being at the top of the stroke, and you get cavitation.   Now that's something I can start to understand.
    I'll have to fix mine but I swear that's how I installed them...because I figured there was a right and wrong way...
    GMSLITHOGMSLITHO Member Posts: 1,561 ✭✭✭✭
    This is my first boat with two props and I never even thought of alignment I have the 4x 3 when I bought the boat the drive was gone so I bought a new drive and props from the same company and no mention of the timing on the props . I’m going to take a look and see where there at .they've been on the drive now for three years so I should probably pull them and grease any way
