More voltage issues. Now at fuel pump relay
Hi all,
So still trying to get all the bugs worked out on my recently purchased 2000 rinker 270. I recently solved a low voltage issue at the helm by running a new wire and now I am having a similar issue at the fuel pump relay. I have battery voltage to the pump relay until I turn the key on and then it drops down to 10 something and it’s not enough to kick the relay in. The relay just keeps tapping as it try’s to kick in. I’ve tried a new relay. It’s not the key switch as it is new and I have tested it. I have not had much time to troubleshoot it but does anybody have any ideas where to start? What sends the voltage to the relay when you turn the key on? Does it come from the ECM? Weird part is if I turn the engine over the fuel pump will kick in. Boats not running well but I think it may be because the fuel pump isn’t getting proper voltage.
