Crankshaft position sensor alarm
TonyATonyA Member Posts: 93
2 hours Into a 4 hour trip got this alarm. Lasted a few minutes then went off. Now what?
2008 Rinker 400EC Longport NJ
  • WillhoundWillhound Member Posts: 4,226 ✭✭✭✭✭
    If a first or first couple of runs for the year I'd suspect just a balky sensor, maybe some condensation, loose connection etc. Especially since it went away. Should be able to pull the connection and maybe spray some contact cleaner in there and put it back together.
  • TonyATonyA Member Posts: 93
    Can you tell me where I might find the sensor on merc 496? Thanks for the help.
  • rasburyrasbury Member Posts: 8,782 ✭✭✭✭✭
    I have dealt with a couple of those sensors over the years...as they start to fail you get the codes...maybe a no start and then a final failure...if the connections look good (had any other work done lately?) then I would just replace it...probably available as a std.,GM part but otherwise probably not a real expensive part anyway. Typically located on the front of the motor dead center of the camshaft.
    Thanks will take a look this weekend.
    Ole Ras is becoming the expert here.  I like it!😁  who says an old car salesman can't learn new tricks.
    Tony, I do agree to start with sensors.  You can always switch between the motors.
    edited May 2020
    That's usually the first thing we do in aviation is swap parts and see if the failure follows the part. Never really thought about it on a boat since I'm a single engine.
    So was there any work done recently on the motor where it would have been disconnected? Check the plug first...then replace the part. There are no moving parts on the sensor so if a good connection, must be on its way out...being on the water with the failure not as bad as an airplane but...
    I think they are relatively inexpensive. Probably wouldn't hurt to put a new one on and just keep the other as a get home spare just in case.
    One of those seldom failures...
  • IanIan Member Posts: 2,998 ✭✭✭✭
    Never seen that comment made before about boat parts.... :)
