Outdrive anti fouling paint
 GMSLITHO
                    Member Posts: 1,600 ✭✭✭✭
GMSLITHO
                    What outdrive anti fouling paint works best for salt water ,I’m on a lake but looking for a recommendation for my brother his drive got eaten up last year on the Hudson and it’s brackish
Now on the subject of anti fouling paint I don't think that would help with electrical current in the water.
https://boatzincs.com/corrosion-reference-electrode-specs.html
The incorrect ‘zincs’ in brackish water can cause problems too.
Galvanic corrosion or electrolysis is much more prevalent in saltwater so you may need zinc anodes and a galvanic isolator.
I think you put the multimeter on the ground block and the other probe in the water and check for current levels. It was a whole process that I never did but I did read about it.
https://www.powerandmotoryacht.com/uncategorized/stray-current-test
