Gimbal ring repair/replacement
Member Posts: 2,998 ✭✭✭✭
So the need may have to be done, some play in the port side so best case the upper pin is shot, likely the gimbal ring is also worn. Will be going the Mercruiser repair route - drill the holes in each side - that apparently is not as easy as the other 3rd party method but I'd prefer to go the way the manufacturer puts in their service manuals. I have seen a few options here and in the web in general around around repair services - send in, weld and machine and return all good again - as well as buying a used part versus the horrendously expensive new unit.
Anyone care to offer feedback on who you have used, experiences etc? Feel free to send private message if you don't want to publicly air a bad experience you may have had with a provider.
Thanks.
Thanks.
I will thnk about that pic everytime I m in shallow water .... or put it in reverse Yeah I had shops that wanted to replace the TA for around $6k Thought that maybe an overkill
I Forgot to mention that my out drive has play only to right about 3" not the left .
The more I research it and having different mechanics look at it im leaning towards the steering arm is rounded out, The ring moves with the outdrive when moving it left to right and theres no up and down play . I wont know forsure until I get it torn down.
The boat in question is a 2000 27' Captiva In good to great condition thats worth on a good day $17k with a 454 b3 . If I had to pull the motor anyway, could see MAYBE changing out the TA but in my situation that just seems like donating to the shops bank account .
