Shift cable boot
rasbury
Member Posts: 8,780 ✭✭✭✭✭
I tried to post this a bit ago but it did not stick...
So recently pulled the transom asy, re did the seal for a leak...re did gimbal bearing and all the bellows. Had a lot of difficulty getting the shift cable boot to stay on to the transom....no matter how I tackled it, when tightened up the hose clamp it would just squish it off the trans part of that makes sense...so on my upteinth time I noted that as I used solvent to get the bellows adhesive off, the rubber was very tack- so the last attempt I left it at that, put it on and it stayed. Then the leak started...so my worst fear was something with the transom asy I did not do right...just looked at the shift boot and right next to the exhaust bellows a friggin tare....also, this is a siera part...I replaced the shift cable Merc...the boot is to tight on the cable so the boot is under constant pressure. . .will get a Merc one..what a pain...
These cold fronts coming trough the south have been rough. It hit us today.
If so i didn't use mercrusier bond i used. Pemrmatex windshield sealer adhesive. I don't like merc bond.
It doesnt harden like the merc bond and flake, it stays flexible. It also acts as as a lube sliding the boot over the lip. You'll need a flexible extension or screw driver to get it tight and straight. Using a cocked socket or extension can cause it to lock off.
I attached mine sitting on a work bench so I may have cheated.
This was an alpha 1
