Awlgrip on blue 342
rmfridayrmfriday Member Posts: 104 ✭✭
Well i got tired of wet sanding and buffing so 3 years ago i tried CostaCoat (similar to Poli Shine) after 3 summers it started to look almost as bad as the tired/clouded blue gel itself. So i decided i am going to try and roll/tip Awlprip.
The boat is kept in a steel building with no heat so i built a "booth" i can heat. I also added two 16" x 16" filtered vents to deal with both the kerosene heat fumes and paint fumes. Below are the steps i have already done and will update as i make progress.
      Stripped Costa Coat with industrial floor wax remover
      Sanded with 180 grit per Awlgrips directions
      Wiped down hull sides with Awlprep
      Primed with 2 coats of Awlgrip 545 reduced with cold weather accelerator
      Sanded primer with 320 grit per instruction
Next up is to apply another coat of primer as i sanded through in a few spots.
I plan on waiting to the weather gets a little warmer to attempt the Flag Blue topcoat.
I will update with pictures when i get a little further along.
