Max size? Chartplotter for 330/340/360
How big can I go?! It looks like about 12” x 12”? I’m considering replacing the C80 with a newer non-widescreen Raymarine and open to ideas.
Thank you!
Thank you!
check out the link below.
https://digitalyacht.net/2013/01/22/getting-nmea-data-to-an-ipad-or-iphone/
Nearly all VHF radios now have DSC. If you get an MMSI number (boatus.com/mmsi) and program it into your VHF radio and it has a GPS signal, then the "distress" button will do all it can do. Which means when you push the "distress" button your MMSI number and your lat/lon are transmitted as a digital signal on channel 70 (NEVER EVER use channel 70 for voice communication) to the Coast Guard who then knows who you are, where you are and that you are in distress. The other use for GPS/DSC is being able to "ping" other boats you know who have the same setup. Given the right combination if you have a friends MMSI number you can transmit a request and if they are in range the data will come back and be displayed on your chartplotter showing their location.
Having AIS is more valuable if you are boating in a area with larger commercial ships like freighters. Again if properly equipped (meaning a VHF radio with AIS function or a separate AIS reciever) you will see vessels sending an AIS transponder signal displayed on your chartplotter.
I have DSC and AIS on the 342. I also have DSC on the center console. I ever have a handheld with GPS built in and DSC. Meaning each has a unique MMSI number and I can perform the DSC function on any of them.
My $0.02
Disclaimer: I'm an amateur radio operator so my interest in VHF radio is a tiny bit higher than some folks. And as a vessel examiner for the U.S. Coast Guard Auxiliary I tend to talk about boating safety.
https://youtu.be/80ITYGAwuok
https://digitalyacht.net/wp-content/uploads/2018/11/DIGITAL-YACHT-2019-US-PRICE-LIST.pdf
While I appreciate that there are alternatives to an expensive chartplotter, I'm just looking to know the length and width of the panel where the chartplotter is fitted. I'm thinking of an older model chartplotter such as an A-Series 12.1" if it will fit.
Thanks.
