shift cable bellows
rasburyrasbury Member Posts: 8,866 ✭✭✭✭✭
Hey @Alswagg
Can I work that cable end through the bellows with out pulling the whole cable since I have already replaced that? How do you do it??
Best Answers
  • rasburyrasbury Member Posts: 8,866 ✭✭✭✭✭
    Answer ✓
    Ok Al.....I knew the answer.... @Alswagg
    Answer ✓
    So this is to pull the cable core through without removing the whole cable?
    Answer ✓
    Huh @Aqua_Aura? Lost me on that one!
    edited May 2020 Answer ✓
     Hey @alswagg is that cable not stiff enough to just push it back up through? Mine is a 270 so it's not a real long cable...
    Answer ✓
    I'm not replacing the cable and I have no idea what that is...
    Answer ✓
    I'll figure it out...always do.
    Answer ✓
    So I got an interesting idea from someone on iboats...leave the cable attached to the out drive, disconect from the sift plate...pull the cable out, install the bellows and pull the cable back through...don't even pull the drive. I'm puzzled this bellows failed so quickly...
    Answer ✓
    The exhaust bellows is off- when I pulled the motor and did all the re work of the transom asy , this stupid bellows was the worst part. It almost seemed that the nub on the transom side was tapered- when you tighten the clamp it just walked off the nub. I tried the adhesive applied and let it sit for an hour, a few hours and over night. It just kept coming off. I think I mentioned above what finally seemed to get it to stick was the solvent I used to clean off the adhesive made it very tacky and it stayed on. Maybe the solvent broke down the rubber? Merc cable and Sierra boot did not fit as it was very tight and really stretched on the boot also- no clip on the end for around the cable.
    So, I ordered a Merc kit which is the bellows, clamp(looks normal to me) and the clip for the tension around the cable. Just got it and for some reason they sent me two, hope that was not a message.
    With the exhaust bellows off and the drive kicked to Port I should be able to get to everything and yes the pull back cord is the mission. If anyone else tries this, make sure you get the heat shield material off the cable by the y pipe as I know for sure, it will not pull through and add many hours trying to figure that one out!
