Flaky fuel level readings
The readings on the gauge are all over. Every where from the 1/4 tank to just over 1/2. I have no confidence in the information. It is an 85 gallon tank, so I don't necessarily want to keep it topped off due to weight. But I want confidence that a half a tank will take me where I want to go. I realize you are dealing with measuring fluid in a moving boat, but I don't trust that the either the sending unit of the Faria indicator, which is part of a cluster, is off. Is there a way to verify that the sending unit is on? I wouldn't be able to do anything with the cluster, except, of course, buy a new boat.
You'll need to have the fuel tank level low enough to pull the until out without spilling fuel.
Have a new sealing washer and fuel compatible pipe doping handy for reinstall.
You should be able to Google the specs of your ohms by part number.
https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwjS8pC7mc_pAhUHjcgKHQPdCQQYABAEGgJxdQ&ae=1&ohost=www.google.com&cid=CAESQOD27cRDF_JV2b7AkRbW6k5xa3X7HU6IXfEdfHmasUPeRHEL0A8pBuDpFNJpIOpopCwW_PMcy5Adh9TXHzKg2Wk&sig=AOD64_1hvEclI2UCmygqiqBgxSnly5xI7A&ctype=5&q=&ved=2ahUKEwiZ3Ya7mc_pAhVJh-AKHU7kDf8Qwg96BAgLEBs&adurl=https://www.jmesales.com/rochester-gauges-6-in-9800-series-sae-5-bolt-industrial-reed-switch-fuel-level-sender/?gclid=CjwKCAjw2a32BRBXEiwAUcugiL1UoIdw-y3-cD--wMjWpTlwG1d71shf0R-b7QrGWUwDKpb1Kkr1shoCMQ8QAvD_BwE
These are more accurate. I have the old school style in my boat, i dont plan on upgrading but i can swap it out in less time than it takes me to drink a beer. When i installed my new fuel tank future service was factored into the new custom tank. 14.99 for the cheap ones and ill replace every 3 to 5 years.
