cleaning the bilge area and motor
rasbury
Member Posts: 8,262 ✭✭✭✭✭
Well, getting into the meat of things on the 270....hate to work on something that is not clean....bilge area is a little funky- little on the slimy side. My son in law suggested a sprayer with a little bleach in it (never know the right mix) will get things a little cleaner and fresher down there but would not want to get that on the motor...motor is all pretty clean but the front could use a little degreasing, not that anything appears to be leaking. Suggestions on getting things cleaned up? It's on a trailer so I have no worries about using a hose to flush it all out....
:-D
purple power will cut it.. so will simple green.. a concoction of dishwashing soap will too- that stuff will cut through grease and oils, in a 75 % water to 25% dishwashing soap solution, and it won't hurt the surfaces encountered....
My buddies in the air wing used to lament 'if you ever get on a bird and don't see any hydraulic oil leaking, get off; It's empty'... maybe that is so, but a clean bilge is another story altogether.. if you keep it spotless you will see any leaks as it happens... I need to clean mine.. :-)
Another interesting idea came from Ray (I think) which was to dump a couple bags of ice in the bilge with some bio soap and take a choppy ride around the bay. Our 270 probably isn't so big that some elbow grease and tlc can't get it done.
While you're in there check the engine oil pan drain area for corrosion/rust (I used my cell phone camera). Mine was nearly rusted through but I caught it in time to sand/re-paint before it failed. Another great save from somebody elses advice on the RBOC forum.
Have fun and this weekend looks like it should be a boating weekend in cntrl Fl. Get goin'
