2003 - 270 Air Conditioner icing up
Stingrayjim
Member Posts: 8 ✭
Hello All - I have "lurked" here for years and am always amazed at the breadth and wealth of knowledge as well as the generosity displayed on this site. So thank you for all of past information and an advance thanks for any thoughts on my question.
My AC blows great for an hour or so. Then this occurs. And the air flow is cut off. I had a marine HVAC tech check it and it was low on R22 he added 4OZ and told me it should hold 12 OZ's total. This pic is after the R22 add by the way The AC is very lightly used but the boat ain't no "spring chcken". The exit vent under the steps blows great, the water pumps out of the side strong (like a garden hose) and the heat works great and thermostat is fine. Two questions - any thoughts on the icing of the intake vent/fins ? And I am hoping access is gained via a panel in the aft berth starboard side. There are upholstry buttons in each corner. I assume if those are popped out there are screws and the panel pulls away?
Appreciate all thoghts and comments!
Just kidding....somehow I thought you were in banking or something? That explains how you afforded those diesels!
So, of course the cabin was not cooling efficently and the compresser is going 24/7. The fix was (already topped off R22 first visit) to run the hoses under the duct and the duct was repaired. The tech also programmed the defrost mode in to give a quick melt should the compressor run more than 1 hour with out the cabin temp lowering more than 1 degree. I ran it this weekend for several hours the flow, as you can imagine was waaaay higher and no icing at all. So I believe this is issue is solved and on to some sticky zippers and isinglass cleaning thanks again for all of the input!!
Jim
