A few systems stopped working for no reason really weird
skyman2112skyman2112 Member Posts: 26 ✭
I went to use my 2008  330EC boat last weekend and found a few of the systems had no power. Its only been a week since i drove it, and it still starts and drives fine. Everything works.... except the engine hatch, anchor windlass, and the engine compartment blower.
  Of course i couldnt find any loose wires in the fuse panel on the dash or the switch panel. So I assume whatever feeds power to to these systems has come loose or broken off. Where on the boat does the harness come from that feeds the fuse panel in the dash? Im new to cruiser boats and theres so many wires i dont know where to look. Thanks in advance for any tips.
    I would start by checking all the connections for corrosion at the switch and battery.
    Don't run the boat without being able to run your blowers.  Dangerous.
  • skyman2112skyman2112 Member Posts: 26 ✭
    It ended up being one of the power wires coming off a bus at the battery charger. Was rusty and broke off
    There you go.  Glad you are fixed up
