LED Navigation lights
Stever00
Member Posts: 145 ✭
I installed a set of those 12" Obcurso lights today. Not to easy getting to wires in anchor rope compartment. They are really bright. I'm kind of concerned they may too bright as to make it harder to see at night or not being legal. Guess I will find out how long the will last. At $ 13.00 it was worth a try. One thing for sure. You be visible to anyone looking.
https://www.lsonews.com/boat-light-strips-must-meet-uscg-standards/
They claim to be 1-mile lights, which would meet the brightness spec. A 2-mile light is safer, but 1 is the minimum.
I hate to say this about any boat project, but personally, I'd press the "undo" key on this one.
Suppose we are approaching each other at night almost head-on, except you'll pass on my starboard side. Normally, I'd see your green light. I'd hold course, or maybe steer slightly to port, and we'd be fine.
With your boat, instead of seeing green, I'd see both green and red. Obviously, I'd have to assume you're coming straight towards me, so I'd alter course to starboard. That could potentially take me right into your path.
You could do a walk around with both your old and new lights on. When you walk around you should see your current OEM lights "disappear" at the correct regulation angles. If your new lights do exactly the same, you're probably OK. If you don't see your OEM light at those angles and still see your new ones, then they do not conform to regs and should either be adjusted to match or removed.
