Acc switch
Has anybody ever successfully located the wires in the bilge from the acc switch at the helm in a 342?  I'd like to wire up lights in the engine compartment and that switch seems the logical choice.  But I'll be darned if I can find where the wires end up.  There are wires on the switch, so I assume they are in a harness somewhere.
Any ideas?
    i had my underwater lights hooked to the acc = sorry i paid to have it done
    I  just added led cup holders and wanted to keep the ones at the helm separate from the others I was going to use that switch but when I took a look at all the wiring there I just closed it back up and will add a switch somewhere else
  • IanIan Member Posts: 2,991 ✭✭✭✭
    I put a switch in the engine bay instead. Local power and activate when opening and closing.
    The wires from my ACC switch where only about 5 inches long just under the panel. must agree put the switch in the engine bay. I was thinking a couple of led strips just around the hatch.
    Sadly I think that a switch in the engine bay is my best option.
    Probably better idea to have the switch at the light itself. Less chance of leaving it on. I might do the same.
    Come to think rarely have I ever had my engine compartment open in the evening/night time.
  • YYZRCYYZRC Member Posts: 5,360 ✭✭✭✭✭
    The engine compartment lights in my boat are wired into the cockpit lights. Not sure if that’s original from Rinker or not?
  • Dream_InnDream_Inn Member, Moderator Posts: 7,821 mod
    That is typical and original.
