Mercruiser 5.0 Oil change
So I went to change the oil on my 1998 Rinker Captiva 212 for the first time the other day. Ran the engine for a few minutes to warm it up, fed the extractor tube on my hand pump down the dipstick tube and started pumping. But the oil just sputters out at a very slow rate. I must have pumped for at least 15 -20 minutes and only got about a quart of oil out. Is there a trick to doing this? Maybe my little hand pump just sucks so I'm thinking I will buy a 12v pump online. Anyone had similar issues? Also, how do I figure out what oil filter is correct? I don't have the original manual but I tried looking up the part number on MercuryMarine.com on the partfinder but can't find it. I purchased a
Quicksilver 866340Q03 and it seems to indicate that it fits almost all Mercruiser engines but I want to be sure.
Best Answer
aero3113
Member Posts: 9,660 ✭✭✭✭✭
I’ve never had any luck with the hand pumps. I have this 12 volt pump, works pretty well. I drilled the middle of a washing machine hose so it will fit over the dipstick tube and screw on. I cut the other end to fit on the pump barb with a clamp.
DasMarine 12V 60W Oil Change Pump Extractor, Oil/Diesel Fluid Pump Extractor Scavenge Oil Change Pump Transfer Suction Transfer Pump + Tubes Truck Rv Boat ATV https://www.amazon.com/dp/B07DCPMP4S/ref=cm_sw_r_cp_api_i_JBd1Eb1ZWCBBQ
The napa is 27099
