Outdrive trim motor assembly mount replacement
My outdrive trim was not working. I trouble shot the issue to the trim motor assembly mount had rusted away and therefore was not grounded. I hooked up a Ground wire to the housing and the trim worked intermittently. Now I need to get a replacement bracket to properly mount the assembly and get a proper ground. Where can I find this bracket?
Im not near any salt water but enough standing water mixed with out humidity can cause some rust after a few years.
