No Hot Water???
After turning on & testing the how water heater I confirmed that it is heating but no hot water coming out. What direction does this valve go? Why do they have a crossover? Just as i confirmed that the water heater was heating i ran out of water. Testing more tomorrow after i fill the tank back up. How big is the fresh water tank?
As to your issue of no hot water, did you open the pressure valve (lift the lever shown on top left) to let air out of the tank while filling? Otherwise the air trapped in the tank will prevent water from filling to the height of the outlet and no hot water.
Need 3 valves to by pass
Air needs to be out of tank by using the blow off valve, even running the faucet the air spits out all over the place but tank still doesn't fill.
52 gallons fresh
48 gallons waste
Remember when the tank runs out to flip the breaker off on the pump.
