flaking paint on lower unit
rkinross
Member Posts: 178 ✭✭
- I would like to repair the flaking paint on my lower unit and prop. I do not know why it is flaking. I thought it might be heat related but it is in the water when used so it should stay cool. It is only occurring below the water line. The prop itself only has minor flaking on the edges. I was thinking some type of sprayed on Rustoleum would be what to use to fix it. Something like this:https://www.amazon.com/Rust-Oleum-249099-Painters-12-Ounce-Navajo/dp/B002BWOS2G/ref=sr_1_25?dchild=1&keywords=spray+on+rustoleum+beige&qid=1591470526&sr=8-25
- What do you think?
Coat with bully dog adhesive promoter as per instructions, prime then paint.
For top side parts or parts that need protection uv you can get eastwood clear coat with hardener in a can.
The adhesive promoter allows plastics, polymers, vinyl, pot metals etc to hold paint that otherwise normally have bonding issues.
