12V Mini Polisher - you gotta get one...!!!
Bought an ACDelco 12V mini polisher, li-ion. Comes with 2 batts.
Got it for all the hard to reach areas. 3 inch wool pads.
Works like a champ. I know Milwaukee & Harbor Freight have similar machines.
Did all the small areas I usually skip.
Recommend 100%
Recommend 100%
Nice thing about this unit is the controlled speed. Used it to fix some gel coat scratches from rafting up with other boats.
2000 grit wet with sanding block, compound with the mini buffer - then hit it with the big buffer & Meguiars Cleaner wax. Perfect result.
Supposed to be awesome tool to use on oxidized headlight lenses too.
