How to Correctly Operate this Trailer Hitch
I just bought a Rinker Captiva 212 last summer. I've pulled a decent number of trailers in my time but I will admit that I've never really seen a hitch like this. Can someone please explain to me, from start to finish, what the correct procedure is to hook up, tow, back-up, and then un-hook this trailer? I can get it done but I usually have a heck of a time getting the coupler to stay open while I'm hooking up. Also I should mention that my understanding is that the lever that says "towing position" and "backup position" has to do with locking out the brakes when backing up which makes sense. But I haven't had to worry about it yet as I'm pretty sure my brakes are not working which is another issue I plan to work on in the near future.
Thanks
Thanks
As far as keeping the coupler open not sure what you mean. Usually you flip up the lock and set it on your tow ball then lock it down
do you trailer a decent distance? if so- i'd consider swapping couplers and introduce an electric over hydraulic system. I trailer about 1/8th mile so i don't worry about trailer brakes at all- the first thing i did was remove them...
Drum brakes give more pad to surface area than disks. They do suck when wet but dry quickly.
Electric brakes are nice, and mandatory in many areas but surge brakes when maintained are reliable and can be used safely.
No need for trailer brake controller with surge brakes.
I tow with a very heavy suv with very wide tires, a 1 ton on 3/4 ton suspension. Im rated for 11,000 lbs towing capacity
I wouldn't fool with brakes on a 212 but with any lighter weight vehicle id make sure they are 100% operational.
If you can do the work yourself rebuilding a surge brake system is simple and cheap. Maybe 250 to 350 max many times.
