Ouch, damaged gelcoat backing into slip. Gelcoat match?
luvinlife
Member Posts: 501 ✭✭✭
I have not had a very good early season backing into my slip this year. The wind has been tough and I’ve been struggling a lot more than past years. Now I think I have the yips and it’s in my head! Well, yesterday I did it, damaged the gelcoat with a big deep scratch. Thank god it’s above the waterline, but it’s pretty bad. I requested the marina take a look and recommend action. Not sure what you guys think about me trying to repair or at least get it sealed from moisture until it comes out in the fall, any thoughts? Similar experiences?
Post edited by luvinlife on
Do as Liberty says above.....
Really straight forward. Take some before/after pics. That way we can judge your abilities......lol
Don't know of its been said, but keep in mind gelcoat shrinks significantly as it dries... make sure and get the overlap recommended by the maker.
It matched pretty good, not perfect tho. be generous when applying. I had to do 2 coats and will probably do another this fall when its out of the water... My scratch is 95% better than what it was. Its just a little hard to do at the dock.
Buy a wet sand variety pack from Advance Auto for like $5 and a sanding block..
I've done a minor patch myself using the iBoats gelcoat repair kit and also had our yard glass guy do more major work on a previous scratch similar to yours.
He matched it perfectly and even up close you could never tell.
Mine attempt passes the "10 foot rule" - but if you get closer, you can tell something was amiss.
Just my .02
https://rinkerboats.vanillacommunities.com/discussion/comment/114230#Comment_114230
This may be the product you need: https://spectrumcolor-com.3dcartstores.com/RINKER-WHITE-WHITE-06-09_p_660.html
