Water leaks from generator
Ran generator for it's weekly 30 minute exercise a couple of weeks ago. Had to go into engine room shortly after and discovered a noticeable amount of extra water in bilge. There was no water coming from thru hull or inlet or outlet to strainer, so figured must be at the genny itself. Would investigate next trip up.
So earlier this week was back up and discovered with genny running, a steam of water pouring from a screw in bottom of "muffler". This should be easy. Go to tighten screw and threads of hole are stripped. Wrapped screw in teflon tape and got it to stop. Never knew that screw hole was there but after finding it I imagine it's to drain water from "muffler" canister during winterization.
So stopped that leak but see another drip of water. The source of this one is a drain tube coming from the siphon break. Since there's a drain tube attached I assume it's normal (at least in some situations) for water to come out of it. Mine's dripping 2 drops a second with genny running. Would that be normal?
Which way were your nipples pointed? Mine were pointed as shown.
I’d say yours is backwards. Look at @Liberty44140 picture above. Unscrew the elbow in your picture, and the tiny “duckbill valve” sits in the “U” shaped part. The duck bill part is facing down, the round part facing up.
I thought it was backwards so I flipped it and reinstalled and it’s still flowing water from the clear hose so I will order new as well.
New on the left.
