VHF radio mounting options
RiverRat232RiverRat232 Member Posts: 596 ✭✭✭
edited June 2020 in Electrical Discussions
I am buying a fixed mount VHF radio and I am looking for options. The helm of my 232  doesn't have a lot of extra space. Any ideas? Pictures would help.
Thanks
  • LaReaLaRea Member, Moderator Posts: 7,860 mod
    Maybe use a black box radio?  The only thing mounted at the helm is the handset.
    Do they make one with AIS? Which model would you recommend? Currently, I am looking at the Standard Horizon GX2200 which I can get for about $300.
    If you are sure you need AIS, I'm not seeing any good options for black box radios.  ICOM has the M400BB, but it uses an external AIS transceiver, and I doubt you want that.  Raymarine makes one with AIS, for (gulp) $1700.
    Standard Horizon has been making good radios for a long time.  That GX2200 looks like a great deal for $300.  So, back to your question.  Maybe you could mount it on the right side, above the speaker.  Put the microphone just below your 12-volt plug, to the right of the steering wheel.
  • aero3113aero3113 Member Posts: 9,329 ✭✭✭✭✭
    You can always get a handheld.
    I think I will buy the GX2200 and see if I can make it work. If not, I can return it. I was thinking I could do something with the map pocket beside the seat.
    I mainly boat on the Ohio River and I am rarely out of cell range but a couple of times a year we go to Lake Erie. That's were I think AIS would be nice to have.
    I have heard that handhelds often under perform. Have you had good luck with them?
  • WillhoundWillhound Member Posts: 4,219 ✭✭✭✭✭
    edited June 2020
    I would trust a hand held as back up only, or limited use. Handhelds typically push out 5 watts max, mounted radio 25 watts so much better range on a big water body.
    But a handheld would be better than nothing.
    Handheld radios are limited to 6 watts of transmit power.  Fixed-mount radios can do 25 watts.
    Speaking of which:  where are you going to mount the antenna?  It has built-in GPS and AIS receivers, but you need an external VHF antenna.
    I have an Icom IC-M93D handheld. But yes, it’s used as a backup and on the kayak. But if it’s your only option it’s great to have, especially with GPS.
    edited June 2020
    I think the gx2200 has an accessory mic for a second helm station.  You could mount the radio anywhere and run the mic to the helm
    I was looking at the same radio
    https://www.thegpsstore.com/Standard-Horizon-CMP31-RAM3-Mic-P4802.aspx
    I am looking at the Shakespeare 5400 XT 4 foot antenna with a bow rail mount.
    That's an idea. Maybe mount the main radio somewhere in the cuddy.
    Yeah maybe...not sure if the effect the GPS reception.
    It may, unless there's an option for an external GPS antenna. And when choosing a VHF antenna, remember that VHF is line of sight. Taller and higher mounted antenna provides both better reception and transmission.
