Bilge?
MiamiAG
Member Posts: 210 ✭✭
Hi,
Anyone with a 290ec tell me what this outlet is? I turn on what I think is the bilge switch on the helm and water will continue to run. If it’s a bilge, I would think it would stop after a while.
its the top left hole.
Thanks,
Art
Thanks,
Art
It should stop eventually or you have a leak letting in a lot of water somewhere.
I would look at that bilge and make sure you don't have a leak asap
Now I'm starting to wonder where the door track drain is. It may be one of those 4 holes on the side and maybe the shower and mid bilge pump share a drain hole on the side.
Like I said in another post, there is also a small gap on the floor that lets water come into the mid bilge from forward on the ship. If it’s that, then I have no idea where it would be coming from as it can be anywhere forward.
Another thing I noticed is that if I run her around for a bit and then hit the switch when I dock, no water comes out. Also, I can confirm that the water does stop after about 2-3 minutes of the trickle pictured above.
It seems the bilge pump in the box is on its last legs. He tapped it and it began running. So, he cleaned it out and it is still working.
We will see if this was the mysterious bilge issue. Who knows! Too many places to leak on these boats!
At least my AC works!
Art
