No Hot Water
Went down to the boat for the first time this weekend. Had no water at the slip so took the boat over to the gas pier which had water. Filled up the water tank and flushed all the lines just like every year. Came back to the slip and turned the hot water heater on for about 4 hours.......no hot water. Ran the engine for about 20 minutes and still no hot water. Not even luke warm. It's almost like there is no water in the tank. Any ideas?
Hamdog
It's strange that it didn't even heat with the engine on. That doesn't rely on the heater element at all.
Can you get in the engine compartment to follow some lines and figure out what is going on?
When they drained the tank they could've also left the drain open. Make sure it is closed as well. The heating elements are pretty simple to change out as well.
Well the Service guy showed up this morning and the lake had risen so fast last night that the walkway out to our slip was underwater. However, they did get the water to the slips turned on. They are supposed to look at it again in the morning.
Anybody familiar with an anode on the water heater?
Does anyone know where to buy the heating element and can it be replaced by me or
do I have to pay someone to do it????
Len
Len & Robyn 342 FV Freebird
it is really easy to do, it just screws in (pull the power first!) use some teflon tape or pipe dope on the threads. It is worth replacing the pressure relief valve too while you are at it.
You can get parts on-line or take your model number and go to an RV store, same exact part and less $$.
