Carbon Monoxide Issue When Running Genny
rmrstlmormrstlmo Member Posts: 238 ✭✭✭
My carbon monoxide alarm(s) are going off when I run the genny. I have three of them – all new last year. I don’t think you can be too careful with this issue. One is an identical replacement for the original which is wired to the boat. Two are battery operated, one of which has a readout. The one wired to the boat is the only one actually going off and making noise. The one with readout hasn’t been high enough to alarm but the readout says 50-90 when the issue is occurring.
I’m missing two of the three screws that hold the top on the genny. I’m trying to find replacements but that has been easy as of yet. They are about 3” long and I’m thinking they are metric. My concern is that even after I find screws and tighten the top on I will still have an issue. The exhaust should be going out the side of the hull. If there is some exhaust leaking at the genny itself, then securing the top might help but there should not be any exhaust inside the insulating cover. A secondary (and maybe related) issue is that the smaller (roughly 8” X 8”) side panel where the fuel line enters is not attached. Finally a third issue is that the bezel where exhaust exits the hull is missing part of the flange.
 I plan on getting screws and securing the top. Attach the side panel and replacing the bezel. Any thoughts or ideas would be appreciated.
Ray
2006 390
Previous 2000 340
Post edited by rmrstlmo on
  • OldDogNewTrixOldDogNewTrix Member Posts: 166 ✭✭✭
    Sounds like you've got 3 areas to fix up and hopefully that will solve your problem.
    Wayne '09 340 EC
    The three screws should be inch thread, they are ~3" long and do not need to be that long.  The cover is only a sound shield and has nothing to do with CO nor the panel covering the fuel filter area.
    I would start by looking over the exhaust hose to the muffler, the muffler, the hose going to the thru hull and finally check the thru hull, mine on my 342 was cracked and you could only see it from outside the boat by looking in.
  • rmrstlmormrstlmo Member Posts: 238 ✭✭✭
    BD, Thanks for the info on the sound cover.  I'm guessing the thru the hull bezel is the likely cause.  Part of the flange on the outside is missing.  See attached pic.
    Ray
    2006 390
    Previous 2000 340
    BD is dead on, fix that exhaust fitting for sure. Then I'd take that battery powered CO det and hold it inside the hull at the thru-hull fittting and start the genset. Feel around that fitting and others for warm air and use your sniffer too. If you get a rapid CO reading start caulking or replace parts. As was said, it may also be a rotten hose or cracked exhaust part elsewhere. None of it easy to get to I'm sure. Good luck and be safe. Mike
