Carbon Monoxide Issue When Running Genny
rmrstlmo
Member Posts: 238 ✭✭✭
My carbon monoxide alarm(s) are going off when I run the genny. I have three of them – all new last year. I don’t think you can be too careful with this issue. One is an identical replacement for the original which is wired to the boat. Two are battery operated, one of which has a readout. The one wired to the boat is the only one actually going off and making noise. The one with readout hasn’t been high enough to alarm but the readout says 50-90 when the issue is occurring.
I’m missing two of the three screws that hold the top on the genny. I’m trying to find replacements but that has been easy as of yet. They are about 3” long and I’m thinking they are metric. My concern is that even after I find screws and tighten the top on I will still have an issue. The exhaust should be going out the side of the hull. If there is some exhaust leaking at the genny itself, then securing the top might help but there should not be any exhaust inside the insulating cover. A secondary (and maybe related) issue is that the smaller (roughly 8” X 8”) side panel where the fuel line enters is not attached. Finally a third issue is that the bezel where exhaust exits the hull is missing part of the flange.
I plan on getting screws and securing the top. Attach the side panel and replacing the bezel. Any thoughts or ideas would be appreciated.
Ray
2006 390
Previous 2000 340
Post edited by rmrstlmo on
The three screws should be inch thread, they are ~3" long and do not need to be that long. The cover is only a sound shield and has nothing to do with CO nor the panel covering the fuel filter area.
I would start by looking over the exhaust hose to the muffler, the muffler, the hose going to the thru hull and finally check the thru hull, mine on my 342 was cracked and you could only see it from outside the boat by looking in.
Ray
2006 390
Previous 2000 340
