Inverters
terrypage
Member Posts: 165 ✭✭
Hi, I am considering fitting an inverter to my 270. I like to enjoy a cup of coffee when I'm on the move, I don't like the idea of lighting the cooker re dangerous possible events. I just wonder if anyone has advice (does it work) I'm wondering if I use the 12volt fitting is it safe on the move? Any comments guys. Terry
I'm toying with the idea of putting in an inverter.
I don't have a generator on board, but the shore power switch in the cabin gives me the option to switch 110V to the generator. So looks like the wiring was already installed.
This is my question - shouldn't the inverter be placed on the generator circuit, to make sure it is isolated from shore power? Shouldn't the inverter use the genset on/off switch in the cabin to keep everything safe?
I don't want to add anymore batteries, if we install an inverter and want to use, I'd only do it with the engines running. Almost every marina here on Lake O has shore power, so we'd only need it on the water to make coffee, or maybe run the microwave for a few minutes. I assume that is okay.
But, if I did it couldn't I just wire it into the genset circuit, so no chords to plug in, just the flick of a switch?
