Vessel View Engine Reading
 TonyA
                    Member Posts: 93 ✭
TonyA
                    Member Posts: 93 ✭
                    Is the bottom reading the pressure of the water going past the impeller and if so with the port engine reading at 4.3 I assume it should be replaced.
                2008 Rinker 400EC Longport NJ
If your impellers were replaced recently, it is much easier to swap sensors port to starboard before tackling the impeller.
What does sensor look like, where is it, and how easy is it to change?
Now here’s the thing. Stamped on the bad sensor is J1207 881879-10 and on the good sensor is J1107 881879-10. Why the difference? Which part # should I order? And where’s a good place to order the OEM part from?
I'm curious why you guys are throwing money at this notoriously unreliable sensor, especially when prior to VV mobile you wouldn't have had the data anyway.
