Rinker 350 Electric issue
                    2008 Rinker 350 Electric issue.  Wife was using hair dryer at same time as hotwater heater and blew breaker at dock pedastal.  Reset pedastal and everything worked fine except the AC 110V plug at the cockpit bar.  I pulled garbage can to see and it is only the romax and a connector.  It does not even share same lline as the fridge and ice maker which each have their own.  It is not getting power anymore.  I checked the breakers on the panel for starboard and port plugs and all the rest work in boat work.  Is there a dedicated fuse\breaker for that cockpit plug hidden somewhere?  I have to believe it is off same breaker as other AC plugs.
