Question for Rinker?
Can anyone give me the exact part and model number of the pompanette portlight windows used in a 99 Fiesta Vee 270? All of them are broken.
Thanks
Stevev V
Thanks
Stevev V
Dave
Try Cindy Scott Hagen who is Rinker parts supervisor at cscott@nauticglobalgroup.com Good luck! MT
In regard to the access to the anchor locker-I own a 2005 320 and my access port is behind the panel under the mirror. Not behind the mirror. Once the Velcro panel is taken off there is a plastic porthole which you unscrew to open. I do not know what you have in your boat but thought I would try. Good luck getting in there-you have to be a magician to get in there.
Now the frig. I have shore power and will explain how mine works. There is a switch panel in the cabin. The left side are the 120 switches and the right side are the 12 volt. On the left side of the switch panel-the 120 side-there is a breaker for the cockpit frig--I turn this on. When on battery power as long as the temp dial in the frig is on, batteries are hooked up and the battery switches are on--the frig will work. When I plug in the shore power or run the generator-the frig automatically switches over to 120.
Hope this helps. Sorry I do not know your particular boat. But hope it is the same idea.
