T.V. Antenna Infos. Rinker 300 express 2007
frenchship
Member Posts: 1,079 ✭✭✭
Hi
Just finish the installation of t.v. In the cockpit ran the antenna cable from the back to the front where the other t.v. is.When I remove the access panel to connect the cable here what I found (see picture)don't know where to plug the cable because the antenna cable for the front t.v.does not seems to be plug to any equippements there,it come from the back of the wall directly to the t.v, should I install another splitter.
Thanks
Paul
Don't worry about Steve' sense of humor - he has a crazy sense of humor - he thinks diesels can run with the big boys (8.2 gassers) :-) You have some great advice on this thread to try out. As well, you could also connect the cable that comes directly from the original signal (TV antenna or cable connection box on the hull) directly to the cable that runs to your cockpit TV - as a test to eliminate all of the splitters. You can buy a female/female in-line connector at radio shack or any like store for about $3. If that works then you can trace your way back through the splitters. Good luck! MT
