Scary video from boat cleaner! - help me diagnose the leak
So I was texted this video today from my boat cleaner. You might imagine my reaction...
I haven't been on the boat for three weeks but the power I can confirm the shore power has been on 100% of the time.
https://youtu.be/uLCNFeSQc9M
This is the inside of my cabin on a 2013 290ec. It looks like the ocean is in there.
I suspect that the mid-bilge is overflowing into the cabin. The mid-bilge area has two holes located behind the steps down into the cabin. I suppose that the bilge-pump(s) in the mid cabin are not working. However, I haven't been there to check it out.
He used a wet vac to take all the water out and dry as best he could.
My question, what would you do? Where would you look?
I realize that most will tell me to haul the boat out immediately. I don't have the easy option at the moment. All nearby marina's are closed or not offering a haul out service. I don't have trailer to put it on in any case.
Any thoughts would be very appreciated.
I purchased a new bilge pump for the general bilge area a couple of months ago. However, it must have failed because I figure the shower one would overflow into the general bilge and then the other one would cover that.
strainer is not cracked. Just checked a month ago when I replaced the AC. The AC evaporation line does go into the mid bilge and it runs constantly in the South Florida heat. My AC guy said a surprising amount of water is generated during the summer months due to the high humidity.
i will turn the AC off and close the valve. I will also close the toilet valve that is there also.
clearly my bilges aren’t working so that is a relatively easy, although annoying, fix.
it has rained torrentially the last week but I don’t think that much can be due to rain. I will taste it to see if it’s fresh.
I’d be shutting off seacocks as others have suggested to stop the potential sources and then see if the mid bilge runs of the float and if not, try the switch.
I think the Admiral may have accidentally hit the wrong switch when I told her to turn off the accessory breakers. I should have checked before leaving the boat...
After three weeks with no charger, the bilge pump could probably draw down both batteries, but it would have to be a bad leak.
I did find out where the leak is coming from but I don’t know the source. Video incoming
https://youtu.be/4zKiuW5mH7w
For safety, you can't turn off the bilge pumps. They are always connected, and they draw from both starter batteries (not the house bank).
my AC is behind the mid bilge and so are all the other thru hulls.
