Windlass stopped working
| Took the boat out last weekend and anchored over at a local beach. Windlass worked fine to drop anchor. As we were going to leave, attempted to pull the anchor up with the windlass, with no luck! I can hear a clicking noise when the button is pushed at the helm. The breaker under my helm seat is not tripped. I am heading down there with my voltmeter at some point this week. Anything I should be looking for?? I should add, the windlass is not working in either direction now. |
If you pull the road out and still have no movement there are a couple of bearings in side that bind up.
I tried replacing parts on mine, and they aren't cheap. I finally bought and installed the 700 as mentioned above and really like it. It is a huge improvement.
Remembered there was another primary breaker in with the battery switches. It had flipped off.
So, maybe check for another breaker? Although you do hear a click.
Boats - you cant rush stuff. Sometimes you have to sit down & reflect.....to figure it out.
