Proper technique to check engine oil level?
YYZRC
Member Posts: 5,367 ✭✭✭✭✭
What’s the best way to check the oil on a 350 MAG?
I have always warmed the boat up to operating temp, let it rest for 15 and then check. Add oil if needed and wait 15 mins and re-check.
starting the engine will agitate water... depending on the type of oil you have in there it either a disperses (separates) it or emergent, breaking it up and mixing it far and wide... not to stir into another oil debate, but it matters depending on how you use and how often you use your boat, which also includes time of season/year.
letting the oil warm exchanges and recharges hydraulic lifters- one thought would be the oil contaminants get mixed up so warming is better... another says the lifters have bled down and the sump won't be fuller than it is right then....
but back to oil compounds- oils high in zinc and meant for marine or classic cars is good for winter... the shear (ability to cling to hard parts) is superior.... meanwhile, oils that emerge the oil allows water to evaporate much faster- which means it isn't resting in the bottom of your oil pan waiting to eat through, and is better for engines that are used a lot whether in the water or not... generally, they lack clinging/shear strength in comparison... use the emergent one during 'the season'.. use the clinger (shear strength) in the off season/storage... it's just a nice thing you can do to your engine that will hopefully come back to you later.
honestly and seriously, i DO level the boat when doing this- and simply by watching the bilge purge of water... i usually do these things after a wash and rinse so there is water in the bilge... after the majority of water runs out, and when i raise the trailer and hear/see more water pouring out- even i trickle- i'll stop... it doesn't mean it's level, it just means it's consistent.... .er... uh... somewhat consistent. I guess i could mark the jack and make it easier...
