Small leak of water in our bedroom , any ideas?
scousine
Member Posts: 74 ✭
We just bough a month ago this boat and as any boat of that many years there is always little things that comes up (hoping they are all little ) We noticed the rug in our bed room, small spot was wet and dried but still a small wet spot bottom right of this picture in front of the cabinet. As there is a sink in the cabinet with water coming in through pipes ,our only thought is may be a leak there. Anyone ever had this situation .
1. Sit in the boat with nothing else on and listen to hear if the fresh water pump kicks on. - My hot water fitting in the bathroom was leaking. Inspect EVERY hose fitting at the sinks and see if there's a leak. If the pump does not kick on at all, then it probably isn't it.
Then:
2. One or two at a time, seal EVERY SINGLE SCREW on the outside, windows and rub rail.
If it's not fixed continue.
3. Reseal windows.
If still not fixed, the last thing is the bow rail screws.. hopefully it isn't that because they are pretty impossible to get in and out as one of them always ends up spinning in its hole.
Lets just hope it's fixed by #2.
