From where within the boat does the thru-hull above the A/C thru-hull drain?
*I mistakenly used the word seacock in my last discussion question* I have a 2007 Rinker 250 Fiesta Vee. I'm trying to figure out where the thru-hull that is located directly above the A/C thru-hull drains from within the boat. Meaning, if water is coming out of it, where within the boat did the water originate? I'm guessing that it is the area around the gas tank but I don't actually know. Thank you!
