Smell in the AC/fan
jandav
Member Posts: 41 ✭✭
How can I get into the space where the toilet tube goes from the toilet into the engine room?
Its behind the wall at the end of the mid cabin bed.
I have a feeling the the toilet tube are leaking in some way.... and I need to clean and replace the tube.
The boat is a 280 EC -2007
Thanks for any help!
Best Answer
davidbrooks
Member Posts: 1,416 ✭✭✭✭
i am not sure on the 280 but on a 342 you have to disassemble the entire rear berth area. The tank can then be unstrapped and removed. I did it last year on mine. I also had the smell. In part some was coming from the actual tank itself as i think that the stink had become embedded in the plastic. The vent connection was an elbow fitting and it was also loose. That may of contributed as well. Does it smell all the time or only when you flush the toilet? if it is when you flush then add a charcoal filter on the vent line.It's 5 O'Clock Somewhere!
Now I want to replace the tube.
The tube seems to be fixed some where in the area that I cant get into.
We are able to move the tube a little bit but when moving in one end you dont see or feel the move in the other end, my feeling is that it is fixed in some way.
It is where the A/C is located.
How can I remove the "wall" in the end of the mid cabin so that I can get into that area?
Any suggestions?
