Amp location
LoveBoat2LoveBoat2 Member Posts: 3
Can't find the amplifier on my 2015 Captiva 276 BR.  5 of 9 speakers are inop.
Best Answer
  • aero3113aero3113 Member Posts: 9,356 ✭✭✭✭✭
    Did they all go out at once? Try moving a bad speaker to a know good location an see if it works.
  • mattiemattie Member Posts: 1,317 ✭✭✭✭
    Mine was same spot. Hull side, under sink. Back wall of the locker compartment comes out. Had some connectors go loose on the amp - same as JoeStang.
    Hopefully you don't have a fridge. I know some of the newer 276's had a fridge as an option. Be a bugger if you have to remove all that.
  • LoveBoat2LoveBoat2 Member Posts: 3
    Thanks JoeStang & Mattie - found amp where you said it would be and that the 4 channel connector panel was corroded - unknown water source but clearly reason speakers inop.
