Trim up and down switch
I'm having a problem with my trim up and down switch. Sometimes it is not raising both drives. Sometimes it does. Trailer switches work fine so I think it is the switch. Can someone tell me how that switch is replaced? Or do you have to replace the whole shift arm somehow?
Thanks
I'll check the wiring at the pumps tonight too, never messed with them, so it sure won't hurt to make sure they are tight
Thank you
As a matter of fact the trim relays are the same one used for the remote starter solenoid up on the top of my 5.7 merc which also failed a few months later. Consistent engineering I guess. At $8 a piece I can't complain too loud. It's a really easy project so I'd say to just do them all rather than wait for the absolute max lifespan.
DUH and Holy crap :-t :-t ..... that's your other problem with the intermittent start issue thread. Having just typed this it dawned on me that I was having the very same problem. Thought it was a neutral switch failing but it was that (censored word) remote starter relay up on the top of the intake manifold. The good news is that it's a super easy fix.
Sure hope that's your issue. Mike
Thank you!!
Got my fingers crossed that it's that easy. If you didn't have another relay or it quit on the water, you can easily jump the smaller contacts on that slave relay to do an emergency/test start. I carry a 12" piece of solid #12 wire that can serve in that role..... and others. Good luck, Mike
I just pulled the entire trim pump assy out of the boat and serviced it on the bench. If your pump assy frame is showing signs of corrosion it might be a great time to replace it with the SS frame found on Ebay and just transfer the parts over to the new frame.
Glad that starter issue dawned on me before you tore apart your helm controls for no reason. It's a relief when your starter issue is such an easy fix. Have a great season in 'Bama. Mike
