Amp location
Can't find the amplifier on my 2015 Captiva 276 BR. 5 of 9 speakers are inop.
Best Answer
JoeStang Member Posts: 1,131 ✭✭✭✭
Its mounted to the inside of the hull behind the wall under the sink. You can probably see it if you take the garbage can out and look to the side of the boat.I replaced mine with an Infinity Kappa Five, and its been a nice improvement.Also my speakers were connected with spade connectors that easily rattle loose, so check that too.2013 276 Cuddy ~ 350 MAG / B3
Hopefully you don't have a fridge. I know some of the newer 276's had a fridge as an option. Be a bugger if you have to remove all that.
