Has anyone ever refinished an old fiberflass vhf antenna?
PickleRick
Member Posts: 3,891 ✭✭✭✭✭
so I will probably never use my vhf but if I remove it there will be a huge gaping hole to cover up.
It had little fibers coming off if it that feel great in your hands.
Step one. Sand with 320 gritt
Step two: clean with acetone
Step three: wipe off as many little fibers as possible
Step four: coat with some 2 part epoxy resin.
There will still be little fibers here and there. Once the epoxy hardens these will become little meat hooks or razor sharp splinters.
So I'll need to re apply a second coat once this starts to tack.
That should give me a good thick base to sand down smooth any strands of fiberglass that intend to stab me or break off in my skin.
I will then go back over her with a 3rd coat of 2 part epoxy resin for a nice base finish.
This epoxy resin is not uv rated so a uv marine paint (epoxy 2 part) will go over the final coat after a bit of 320 gritt sanding to ensure she sticks.
Update pics will come as i get more done. This is just the first coat.
I've turned it on and while there is no one to hail I was able to pick up the weather forecast from hedersonville nc and I think Asheville so she's in pretty good working order id say.
I have no idea how to do that. I'm refinishing it while attached to the boat. All i know about the vhf is how to turn it on, adjust volume and scan channels
I'm not on the lake this weekend so I'm doing crap around the house. Had planned on a wheel bearing replacement on a buddies fj60 for a few extra bucks but he got me the wrong parts.
I get bored sitting around doing nothing.
We were on the water last week from wed until Monday afternoon. The admiral didn't want to hit the water this weekend. She closed last night and today.
I could have used polyester resin as i have some and this was made of polyester but I don't plan on ever doing this again.
Epoxy will make a more durable and stronger bond.
It also flakes and cracks less than polyester. So it is more flexible than the the antenna it is coating.
Polyester also doesn't go on as thin. You need to thin polyester resin to prep into wood for absorbsion to lay fiberglass over it. I do this with 50% acetone. Generally this leads to a much longer cure time compared to what polyester resin normally cured. Its the best way I've found to thin in order to absorb into the wood to help form a good chemical bond. Without the chemical bond you only have a mechanical bond to sanded wood.
Epoxy resin just needs a good sanding on the wood then cleaning with acetone. Once dried shes ready to roll/brush on a coat of epoxy, let it dry a few hours before laying fiberglass over it.
Both methods work but you use less epoxy to do the same job, less fiberglass, no crazy fumes and much longer cure times so you can lay multiple layers over a day or two without sanding so long as you use proper hardener in approximate temp range.
Are you putting gelcoat over the epoxy covered holes?
It looks good as in I can't see where it was repaired
