Waeco fridge maintains different temps at 120 AC and 12 volt
Spurred by a thread from @YYZRC, I did some research into my galley fridge that doesn’t maintain temp very well when on hook. I believe the model is 1110. Thermometer is set to 7, “full on”. At dock, overnight, plugged into shore power, fridge goes down to around 30-35. Freezer down to -4- +1. Out on the water for a day, with cabin temps rising to 79-82, fridge will rise to 46-53, and freezer to 30-35. 2 house batteries are on 3rd year, but by end of day on water, voltage at meter does not go below 12.2, and measured directly at batteries, 12.4.
Testing the door door seals with a dollar bill, it slides out pretty easily anywhere on the door. So I suspect seals are not great.
My thought is that with the battteries staying within a safe range (12.2) the fridge is getting full power and batteries is not the cause of fall of.
I’m sitting at the dock this afternoon on shore power and despite the cabin being 79 degrees, the fridge is maintaining at 33 degrees (certainly colder than I need). So despite weak seals, fridge is able to maintain temp in a warm cabin.
Out on the water we open the fridge some, but not very often with just the 2 of us. I can understand a little drop due to that. Open it less on shore.
I don’t believe this is typical for fridge boats as we checked my daughters Bayliner (my former boat) with 1 year older house battery and her temp was the same on the water at end of day as it was in the morning at the dock. And thermostat is not even set to full.
Does AC power make the compressor run inherently more efficient to account for this? (I wouldn’t think so based on daughters boat).
What would account for my differences and is there something I can do?
I will replace my cockpit fridge over the winter and I will keep messing with the cabin fridge. I will pull the thermostat out and see if it can be adjusted as per Handy’s comments above.
i think the fact that you recover on the hook is very telling. Seems battery is not the issue, and like you say, old compressors that can’t keep up with the daytime temps, and loss of cold from door openings.
