Cabin door handle?
Hey guys, do any of you have a hard time opening the cabin door? Ever since we purchased this FV 290 the cabin door has been pretty hard to open and close, takes a bit of effort, not bad for me and I honestly don't think it is so bad, but the admiral complaints about it all the time lol
I am thinking about installing handles on both sides (inside and outside the cabin). Any ideas? I was looking at this, but not sure how it will look:
https://www.boatoutfitters.com/stainless-steel-grab-handle-6-80
I believe this would make it easier to open/close. Thoughts?
Thank you!
Bert
Thank you!
Bert
They do get hard to slide. Try spraying the slides with silicone spray or WD-40. It will help a lot, although you have to reapply every month or two.
Good points all of you, the track is not so nice, I guess the previous owners used "grease", which is the dumbest thing to do, just not easy to clean to be honest because unless I take half the helm apart I can't get to most of the track, I will try cleaning it more and then using some good old WD40 to see if that helps.
LaRea I don't have a screen door, so that wouldn't be an issue, but you guys are all right, I am going to try to use some WD40 or something else, just cleaning the tracks is a PITA!
