Who's good at reading spark plugs?
LaReaLaRea Member, Moderator Posts: 7,946 mod
edited August 2020 in Engine Discussions
Anybody want to offer opinions on what these spark plugs say about the health of my engines?  @212rowboat, @69fastback ?
2007 Rinker 370
Merc 496 engines with 800 hours
Plugs have 300 hours
[EDIT:  plugs are AC Delco 41-983, platinum plugs]
After replacing plugs and wires this weekend, I noticed an immediate bump in performance.  Cruise MPG improved by about 9%, getting back up to what I recall seeing a few years ago.  I attribute the improvement to the wires, not the plugs.  The wires were probably original, and two wires had severe chafing damage.
A few things I noticed about the plugs:
  • S8 is cleaner than the others.  That's one of the plugs with a damaged wire.  It's possible the plug was not sparking at all.
  • S4 is a little bit shiny.  Oil fouling?
  • P3 has some crusty buildup on the side of the insulator.
  • P7 has corrosion on the outside ... maybe a water leak that I need to investigate.
Post edited by LaRea on
    I am interested also. I just posted another set of plug pics on another thread a few days ago. I would think you would want to look at your new plugs vs these. With a new set of wires the new ones could look quite different. I had about 150 hrs on my pkugs and also saw a marked improvement and that was putting in cheaper plugs. I pulled out the NGK Iridium.
    S8 is not firing. S4 looks like oil possibly a leaking valve. P7 looks like maybe it got saltwater on it 🤔 P3 maybe running rich but I'm sure someone more knowledgeable will chime in. Is this carburetor or injected?
  • aero3113aero3113 Member Posts: 9,602 ✭✭✭✭✭
  • LaReaLaRea Member, Moderator Posts: 7,946 mod
    Injected.  I wish I had kept track of which wires had chafing damage.  S8 was one, and there was another one on the starboard engine.  I think this was S8:
  • PickleRickPickleRick Member Posts: 4,243 ✭✭✭✭✭
    I've met a few guys who can tell you ring wear oil consumption or valve seals, valves not seating, etc
    My speciality is 2 cycle so I only worry about grey plugs(lean)  i want charcoal wet ground straps. No valves or oil rings to worry about.
    Ill also be following this thread closely.
    Old and new.  These are AC Delco 41-983 (platinum, not iridium).  None of the plugs had any major change to the size/shape of the center electrode.  And remember, the plugs only have 300 hours on them.  I only changed them because I was doing wires, and it's not much extra work to change plugs too.
    Sorry, I can’t help. Diesels have no plugs. LOL
    I wouldn't say only 300 hours. That's like putting 50k miles on a car (my educated guess) could be more or less depending on how you run the boat. I think 300 is the change interval as well.
    Liar...they have glow plugs.
    How do the efi motors do at idle/trolling speeds vs carbed?  Even with my Holley dialed in by one of the best in the carb industry i still needed some wot after long idle times to clean the plugs.
    edited August 2020
    I idle every time I go out for about 20 min since the channel is no wake out of the marina,also I leave it at idle tied up to get to temperature and make sure all is well. It runs perfectly smooth for me. Never have to power up to clear up the motor. Just like a EFI car it takes care of itself mostly.
    I did the plugs when I got the boat from someone who probably couldn't spell maintinince and they looked all normal and matched.
    Although I do a lot of 1000-RPM cruising, my last run before changing plugs was 3 hours at 3900 RPM.  And I do enjoy a few minutes at WOT every now and then.
    My Yans didnt
    edited August 2020
    My Yans didnt
    Did it have a probe in the intake or engine mount fuel filter assembly?  Usually they have some place to heat fuel or air when operating at or near freezing temps
    Never freeze in Florida
    edited August 2020
    A couple of years ago it got down around freezing in the keys.  The iguanas were falling off the trees.
    A guy picks them up for food or maybe bait.  Once they warm up they come to life and go ape $hit all in this guys car and causes him to wreck.
    Post edited by raybo3 on
    300 hrs on a set of plugs is a lot IMO. Consider you are running 3-4x the rpm over your car while on the hwy.
    In one of the other threads, @Alswagg said the Merc recommended service interval is 500 hours.  Maybe that's for iridium plugs.
    edited August 2020
    Iirc 100 boat hours = 10,000 miles.
    500 hrs on a set of plugs sounds about right on new efficient efi motors.  300 wouldn't hurt.
    Hard to get a good reading on plugs without being able to see down in them.
    Ahh ... hopefully these are better.
    Definitely better.
    I’d say, overall, those look pretty good for 300 hours. S8 definitely looks a tad lean. Looks like P3 May have some valve seal/guide seepage.
    Better pix of P3 ... definitely the odd duck of the group.
  • IanIan Member Posts: 2,998 ✭✭✭✭
    Of course it does, thats why they spray the fruit trees with water so it freezes and protects the fruit to sub freezing temps. Maybe not last year but I think the year before.
    Florida ain’t the paradise Floridians want it to be... :smile:
  • YYZRCYYZRC Member Posts: 5,363 ✭✭✭✭✭
    edited August 2020
    Here’s mine. #2 will be done when I flush my heat exchangers - just waiting on the end gaskets to come in.
    There was a lot of rust that flaked off on the underside of the manifold at the stern (plugs 7 and 8).
    How many hours?  The insulators look cleaner than mine.  I had manifold rust near P7.
    I have no idea. Boat has 550 hours total. I’m guessing the plugs and wires were original since the wires have some red and green tape on them. Did the cap and rotor. Will save wires for spring.
    Anyone know when Merc went to electronic ignition? My Volvo is an 06 8.1 so no cap and rotor. I was just surprised to here cap and rotor still on the post 2000 engines.
    Starboard motor hasn’t been running well. Pulled the plugs today and one was bad. Used this thread to help diagnose!
